ASD relay ?
Old Jan 28, 2008 | 07:21 PM
randypape's Avatar
randypape
Default ASD relay ?
On my 98 Dodge Stratus, I am not getting voltage back to the fuel pump plug, from the power distribution center. When I checked both the fuel pump relay, and ASD relay, they both checked out fine. When I checked for voltage at pin 30, inside the PDC box, for the ASD relay, I got 12 volts. Then at pin 86, for the same relay, I got 12 volts with the key off and I am only suppose to get the voltage at that pin when the key is turned on. Is this telling the PCM to turn off the fuel pump and ignition? The car is in a no start situation. I am getting spark with my spark tester, but the fuel pump isn't turning on, so this seems like a fuel issue to me now. I can't find anywhere where it talks about having voltage at that ASD when the key is not turned on. Any ideas?[/align][/align]Thanks[/align]Randy[/align]
Old Jan 28, 2008 | 08:32 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: ASD relay ?
https://dodgeforum.com/m_554757/tm.htm
I'm assuming it uses the same as the venge .... Hope that helps ...
I'm guessing the fuel pump relay is bad and the ASD is shutting it down it needs the fuel pressure to continue
