Noisy strut passenger side
Old Apr 13, 2008 | 09:36 PM
pixelpadre's Avatar
pixelpadre
Default Noisy strut passenger side
I have a clunking noise coming from the passenger side strut everytime I hit a bump but not usally with dips and holes.[/align][/align]Suspension seems to be perfecgt but the noise is driving me crazy.[/align][/align]Please help.[/align]
Old Apr 14, 2008 | 10:31 AM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Noisy strut passenger side
check the bushings , isolator plate,ball jointsand the strut bar end links those are the normal noise causers
Old Apr 14, 2008 | 10:48 AM
pixelpadre's Avatar
pixelpadre
I tightened down on the nut at the top of the strut and that seems to have quieted it down a bit. Is there something that needs to be replaced or should I continue to tighten it down?
Old Apr 14, 2008 | 05:00 PM
bad venge's Avatar
bad venge
Section Moderator
Top Center bolt ??? in the middle of the strut tower ???
Top bushing is shot/worn
Old Apr 14, 2008 | 05:34 PM
pixelpadre's Avatar
pixelpadre
Is that an easy job for me to replace? Strut appears to be doing its job. smooth ride even tire wear. thanks
Old Apr 14, 2008 | 06:01 PM
bad venge's Avatar
bad venge
Section Moderator
It's not a terrible job ... I'd do BOTH since they should have near even wear ....
Remove the struts , use a spring compressor remove the top plate, install the bushing, while you are at it I'd do the rubber Isolators under the top plate retighten then reinstall ...Last set I replaced was $36 for the pair bushings and isolator plates
Old May 7, 2008 | 11:47 AM
john1782's Avatar
john1782
Had the same problem checked today on my 02 R/T, was told replacing the front sway bar links would fix the problem.
Old Jul 16, 2008 | 02:07 PM
DMark's Avatar
DMark
ORIGINAL: pixelpadre..... I have a clunking noise coming from the passenger side strut everytime I hit a bump but not usally with dips and holes......
pixelpadre,
Did you ever find a fix for this problem?
I have the same clunking noise with my 2002 R/T.
Thanks,
Old Nov 1, 2008 | 10:07 PM
pixelpadre's Avatar
pixelpadre
Default Still Clunks
I still have the clunking noise driving over bumpy roads.
Old Nov 6, 2008 | 07:31 PM
nocacapantz's Avatar
nocacapantz
Talking
We had a clunking noise on our stratus and it was the ball joint and tie rod end on one side. The guy that fixed it said it was hanging by a thread! Whew!
