newbee
iam new and need some help my son has a 95 dodge stratus es 2.5 liter
the problem is the heater it blows fine through the defrost and when you switch it to floor or any other place it will not change it stays on deforst. is this hard to fix and iam sure i will have to take dash out to find the problems.
thanks for the help
thanks for the help
Good news... could be as simple as replacing the AC controls. Sounds like the **** that switches from defrost to other settings, isn't working. It is easy to swap out too. just pull the bezel from around the radio/controls (no screws, but you will need to use some even force, starting at the top of it). The rest should be easy to figure out. If this dosen't work, than post back with what you did, and we'll figure something else out.
