2004 Dodge Stratus Help
Old Oct 12, 2008 | 05:56 PM
Mommytobe1's Avatar
Mommytobe1
Question 2004 Dodge Stratus Help
Hello
I have a 2004 Dodge Stratus that I've had in the shop 6 times with in the last couple months due to a clunking noise it makes off and on somewhere behind the drivers side tire. I've had new tires put on it, new swey bar links, a four wheel alignment, new break pads on the front etc. So this noise it usually don't start until I'm out driving about 60-70mph. The weird thing is I've have taken this to a dealership 2 times to have it looked at and they cannot find this noise. Does anyone with a Dodge Stratus know what I'm talking about and can help me? The weird thing is that it doesn't do it all the time if I'm driving in town but it all starts when I usually am driving out of town or for a while at speeds of 60-70 mph then once I get back in town driving 35mph it will still do it until I park it. I can feel it also through my floorboard where my foot rests. Help!
Old Oct 12, 2008 | 06:47 PM
bad venge's Avatar
bad venge
Section Moderator
sounds like bad lower control arms/bushings to me
Old Oct 13, 2008 | 06:26 PM
Mommytobe1's Avatar
Mommytobe1
I forgot to put that in there. My lower control arms have been replaced. Nobody can figure this out. It's really frustrating.
Old Oct 13, 2008 | 06:52 PM
bad venge's Avatar
bad venge
Section Moderator
There are TWO a straight and curved arm have they both been replaced
Old Oct 15, 2008 | 01:18 AM
Duo.Maxwell's Avatar
Duo.Maxwell
Check your halfshafts. Look under the car and feel to see if the rubber boots are greasy or broken. Other than that, it's most likely your transmission...I had almost the same problem....would do a clunk clunk clunk clunk that would get faster as the car moved faster (only happened at higher speeds). I thought that it was my half-shaft so I tried replacing it...solved it for a little while but then it started again. A week later a tooth broke off of a gear in the torque converter housing and punched a 2" hole in my transmission. So,
1) Check half-shafts
2) Check tranny (aamco)
Good Luck,
Duo.Maxwell
