i need some more power.....
Old Feb 7, 2005 | 07:50 PM
CoyoteRoede's Avatar
CoyoteRoede
Default i need some more power.....
i am lookin for a few more ponies under the hood. i am going to be getting a intake and i have already put a free flow exhaust on. i was thinkin about putting on new performance plug wires. any other ideas that arent really expensive.
Old Feb 7, 2005 | 10:58 PM
moparturd's Avatar
moparturd
Default RE: i need some more power.....
Don't waste the money on plug wires or ignition unless you're really throwing some serious fuel and compression to the engine. You might want to look into a TB. Send fastman an email and see what he can do for you. Try and find the lightest aluminum wheels you can find if you are going to upgrade that.
Good luck.
Oh yeah Make sure the intake you get is a true cold air set-up and doesn't pull in air from the engine compartment.
Old Feb 14, 2005 | 04:36 PM
Roadrunner71's Avatar
Roadrunner71
You could put a set of pulleys on your car but that really won't help you with HP that is more torwards Torque.
MoparTodd is right don't waste your time with anything on the ignition right now. It's really not going to do a whole lot for you in the HP aspect. It will make your firing system a little smoother.
Also do make sure it's a true cold air intake. That heat from your engine really sucks compared to cooler air.
