2001 Dodge Stratus Fog Light Lamps.
Old Aug 17, 2011 | 12:40 PM
kbcnick's Avatar
kbcnick
i know this thread is extreamly dead, but couldnt you just set up a relay, tapping into the fog lights on the headlights? you could just use the power wire for the stock fog lights, and make that your switch for the relay, run a power and ground to the relay, then your power out to the new fogs? sounds way easier than the article said, plus then you wouldnt have a tacky switch on your dash.
