Blower Motor HIGH only
Old Feb 6, 2004 | 05:52 PM
lanzelot's Avatar
lanzelot
Default Blower Motor HIGH only
The blower moter works only in HIGH in my fiancee's dodge Stratus 1999.... I do not know what could be the problem, the relay,? maybe....
but which one it is... in the owner's manual does not say anything about that blowe motor relay....
I need help, it is to hot in my car... What and Where in my fiancee's car is the problem?
Thanks, thanks, thanks....
Ed.
Old Aug 11, 2005 | 09:43 AM
thump186's Avatar
thump186
Default RE: Blower Motor HIGH only
there was a TBS about this. It is caused by the resistor board inside the tempature control unit itself.
Old Aug 12, 2005 | 01:26 AM
tenntech's Avatar
tenntech
Sounds like a bad blower motor resistor. It's located under the right side dash area and mounts on the bottom of the heater box.
Old Aug 25, 2005 | 11:13 PM
hemipower1984's Avatar
hemipower1984
replace blower resistor it is held in by 2 5/16" screws 8mm will work to lower dash right side.
Old Apr 19, 2006 | 12:47 AM
John_E's Avatar
John_E
The replacement blower motor resistor for my 2003 Stratus looks considerably different than the original. I had to carve out the plastic mating connector under the glovebox, but so far everything is working well. I hope this new one lasts longer than the original, which looks like a flat metal plate. I understand this is a weak spot on these cars.
