1995 dodge stratus no start
Old Mar 11, 2005 | 11:27 PM
al010101's Avatar
al010101
Default 1995 dodge stratus no start
i bought a '95 stratus, runs great on starting fluid, the fuel pump cycles, we jumped the pump to see if it would run longer than prime and it sounded fine, but we're barely getting a trickle out of the fuel line in the engine bay, anything common happen like this on stratus/breeze?
Old Mar 12, 2005 | 03:41 PM
PearlStealthRT_TT's Avatar
PearlStealthRT_TT
Default RE: 1995 dodge stratus no start
plugged fuel filter, leak in line, crack in pump, or taking in air somwhere
Old Mar 15, 2005 | 03:33 PM
al010101's Avatar
al010101
fuel filter is clean, dropped the tank and pressurized the pump, putting out maybe 15psi max, replaced the fuel pump, got about 45psi, then heard a `pop` and now that one hovers around 12-15psi aswell
Old Mar 17, 2005 | 01:52 AM
dishdude's Avatar
dishdude
MIGHT WANT TO CHECK ELECTRICAL... AND THE LINES THEMSELVES.. DEPENDING ON THE 'POP' YOU HEARD.. A LOUD POP COULD MEAN BLOWING ANOTHER PUMP.. IN WHICH THE LINES COULD BE CLOGGED.. CORRODED.. OR WHAT NOT... CHECK THEM FIRST.. OR THERE COULD BE AN ELECTRICAL SHORT SOMEWHERE.. AND A RELAY IS 'CATCHING' .. HAPPENED ON MY 88 SAFARI I HAD
