Oil pump location on an 02 R/T?
Had the oil changed 3 months ago and was told I had an oil leak, though checking the dip stick weekly says I haven't lost any. After I've driven the car a bit I do notice a slight smell coming through the vents, did some looking around under the hood and found the following:
Valve cover bolts were loose
Firewall on the passengers side about 3/4 down..( several metal tubes connect to a central spot) have oil residue on them, it's the only oil wet spot I could find. Just wondering if the oil pump was any where near that area and if it could be giving off a slight spray. Also I have detected no oil drips when the car is left sitting.
Thanks
Thanks
