2000 Dodge Stratus won't start when low on gas
Old Nov 28, 2009 | 09:04 PM
alan1213's Avatar
alan1213
Default 2000 Dodge Stratus won't start when low on gas
I have a 2000 Dodge Stratus. Whenever my gas gets to a quarter tank or lower, it wont start. I'm not saying when I'm out of gas, I could still have a quarter tank left, but it wont start.
If I start it before it gets that low, it will run til its out of gas. Also, its always able to start right after I shut the car off, but if the car has been off for a while and the gas is semi-low, it won't start. I had the fuel pump go bad and I replaced it. The car started doing this after I replaced the fuel pump. I have dropped the tank again and the pump seems to be sitting in the tank correctly.
Can anyone help me out here? I've never heard of a car doing this.
Old Jan 8, 2011 | 08:09 PM
2000 Stratus es's Avatar
2000 Stratus es
Any Solutions to this problem? I have the same exact issue.
Old Jan 12, 2011 | 06:09 PM
GALVANIZEDYANKEE's Avatar
GALVANIZEDYANKEE
Can you hear the pump running? Does it stop after a while. Check the fuel pressure at the fuel rail. I'm not sure of your situation. If all of the above checks OK check the ignition. If it does this after a short stop period and is OK after an overnight, it may be a heat sensitive ignition system.
