99 Stratus Electrical Issues
Old Feb 6, 2010 | 04:31 PM
roberd19's Avatar
roberd19
Default 99 Stratus Electrical Issues
Trying to help a family member fix their 99 4cyl Stratus. The car has some strange electrical issues- the wipers and horn will activate when they turn on the headlights. They have removed the fuse for the wipers as a temporary fix. Searching the forum it's seems as if the multi function switch might be a possible culprit. Anyone dealt with this issue and if so how did you fix?
Old Feb 8, 2010 | 07:47 AM
ratsttam's Avatar
ratsttam
Not sure if the switch will be the culprit here. The switch (both left and right arms, and flasher button) are one module, with 2 separate wire harnesses attached to the back. The horn is not part of this. I would look beyond at the wires going down the steering column. The clockspring (which has the horn and cruise control wires running through it) is a failure point on a lot of vehicles. Definitely sounds like some wires that the insulation is worn through and are now touching.
