hey im confussed
Old Mar 29, 2010 | 07:36 PM
cantfindproblem's Avatar
cantfindproblem
Default hey im confussed
Ihave a 96 breeze and im getting 2 codes a12that shows problem with battery conectionand a 43 multi cylinder mifire.PEAK primary current not acheived withnmaximum dwell time, I changedplugs and wires and check for power on the wire powering the coil. everthing is normal. Isthat a problemin the coil oranybody ele havea idea. couldit be a ground problem????
Old Mar 31, 2010 | 08:48 AM
ratsttam's Avatar
ratsttam
Battery disconnected seems to be "normal" if the battery has been removed, dead, or is otherwise failing. That code stays in the system for something like 20-50 cycles.
The coil or distributor is a common source of "multi-cylinder misfires". You mentioned that there is power going to it, but didn't mention if your plugs were firing properly.
Also, It would be good to know what engine you have (2.0, 2.4, 2.5v6) and any other symptoms (running rough, pinging noises, knocking, etc...)
