2006 stratus - is possible to switch motor
Old Apr 11, 2010 | 01:44 PM
kaebear21's Avatar
kaebear21
Default 2006 stratus - is possible to switch motor
My mom had a 2006 stratus - well the car had a major oil leak we were finally able to find out a seal is bad. Local mechanic just did the same repair to same car and in less than 2 miles the motor seized. From what I understand we just need to replace motor is it possible to use motor from 95 stratus? We have a 95 stratus the transmission needs replaced and the 06 needs motor was hopine these parts would just swap if possible which would b easier?
Old Apr 12, 2010 | 08:13 AM
ratsttam's Avatar
ratsttam
It would be most helpful if you could post back with the specs (number of doors, engine size, trim level) of BOTH cars. If you are talking about both 4 door (95-00 was only 4 door), and both the 2.4l than it MIGHT be possible to do a swap, although I'm sure there will still be a lot of modification to the wiring harness as the computers are likely different. Also, if you have the 2.5v6 in your 95, and a coupe with a 3.0, there might be some compatibility there also.
Just do not expect it to be a direct drop in.
NOTE: 95 was an odbI hybrid (used odbII plug, odbI computer, some free reading parts stores cannot read your codes). Your wire harness WILL be different!
As a side note, both cars should have a 41te transmission, that might be easier to swap to get the 95 back on the road
Take a good look at BOTH engines, and see if they are the same, if the mount points and clearance match, and location of wire harness, etc...
