newbie 97 stratus 2.4 leaking oil
Old May 10, 2010 | 11:11 PM
hawker71's Avatar
hawker71
Default newbie 97 stratus 2.4 leaking oil
Hi just joined the forum was hoping to get some input from you fine people
I noticed oil was leaking from the top of my oil filter loosing about 3 litres
a week bought another filter thing this was the problem but it wasnt been using fram oil filters
any thoughts oil filter is tight pleas email fstilla@shaw.ca
Thanks Hawker
Old May 11, 2010 | 08:11 AM
ratsttam's Avatar
ratsttam
I'm not quite sure what you are asking here. So the one filter was leaking, and a new one is OK? This can happen if the o-ring isn't removed before installing the new filter (which should come with it's own o-ring). So there is two common problems, the old o-ring still being there, or the new filter not having an o-ring.
Are you saying that you've never had a problem with fram oil filters? Or are you stating that you've never used fram oil filters, and this one was leaking?
Old May 11, 2010 | 04:15 PM
hawker71's Avatar
hawker71
Default oil leaking from oil filter
Yes it is still leaking even after replacing with new oil filter
cleaned surface first with brrake cleaner then applied new filter
Old May 11, 2010 | 07:06 PM
hawker71's Avatar
hawker71
sorry for the grammar should have said I was thinking the oil filter was the problem but it wasnt
Old May 11, 2010 | 08:37 PM
hawker71's Avatar
hawker71
Default 97 stratus oil leak
After furter investigation the oil leak is coming from somewhere above leaking down the oil filter
ANY IDEAS GUYS?
Thanks
Old May 11, 2010 | 09:43 PM
ratsttam's Avatar
ratsttam
At that age, the oil pan gasket may be at fault. It's a pretty messy repair, but pretty simple none-the-less. If you find its coming from even higher, you might have a failing valve cover gasket (i've had to replace mine already). Give it a good look at, and maybe even clean the engine bay with de-greaser from the car wash, and see where it's at the next day.
