2004 stratus brake lights
Old Aug 1, 2010 | 04:37 PM
countryboy1130's Avatar
countryboy1130
Default 2004 stratus brake lights
my third brake light works but the two others do not. i changed bulbs n still nothing. any ideas?
Old Aug 1, 2010 | 05:00 PM
GALVANIZEDYANKEE's Avatar
GALVANIZEDYANKEE
Default Stop Light
All of the stop lamps go to a common junction. Get a voltmeter and make sure you are getting voltage to the side lamps when you step on the brake. This is the center of the socket. Its a white/tan wire. If it is there your ground connection is bad.
If it not there you have lost connection at to the common junction.
Old Aug 1, 2010 | 09:37 PM
countryboy1130
Default stop lights
hey thanks i'll def try that! appreciate the help
