How to ENABLE (Yes, enable) the seat belt alert
Old Aug 11, 2010 | 08:53 PM
Foxchase's Avatar
Foxchase
Default How to ENABLE (Yes, enable) the seat belt alert
Hey!
Apparently, my seat belt alert must be disabled, because there's no sound coming. As the little tech- and safety freak I am, I would like it ENABLED.
Any way to do that? Is it like the same as DISABLING it?
Old Aug 12, 2010 | 08:19 AM
GALVANIZEDYANKEE's Avatar
GALVANIZEDYANKEE
You did not say if both seats (driver and passanger) don't sound the alert. Check under the seats to see if the plug us connected.
Old Aug 12, 2010 | 11:16 PM
ratsttam's Avatar
ratsttam
I don't recall the passenger side chiming out if unbuckled with a person sitting on it. That'll be something to test when I get back home...
I do agree that you should check the plug under your seat for corrosion or even if it just came loose. The switch inside the receiver may have failed also, or got stuck in the "in" position (soda?) making it think that it IS buckled.
