How to disconnect 2002 Status Cruise Control?
Old Oct 20, 2010 | 02:57 PM
plathw's Avatar
plathw
Default How to disconnect 2002 Status Cruise Control?
I was trying to tackle a problem and got this response:
"I can't remember if there is a fuse or not but if there is, pull the fuse. Otherwise, pull the connector from the cruise control control in the engine bay. It's on the drivers side by the brake master cylinder."
I tried looking for this, but could not find it. Does anyone know for sure if there is a fuse for it, or where exactly I unplug?
Old Oct 21, 2010 | 11:27 AM
GALVANIZEDYANKEE's Avatar
GALVANIZEDYANKEE
Your Owner's Manual should have the fuse layout. Why can't you just turn it off?
Old Oct 22, 2010 | 10:12 AM
plathw's Avatar
plathw
It does have a fuse layout, and I have looked over it 100 times. Is it possible that there isn't a fuse? I can't find anything in the layout that even sounds like something for the cruise control
Old Oct 23, 2010 | 11:49 AM
GALVANIZEDYANKEE
The fuse is a multi-function fuse. If you pull it other itms may not work. On the bottom of the servo unit there is a four pin connector. You can disconnet it to disable the CC. There is also a vacuum line going to the top of the servo. You can pull it and plug the line. Then, there is the cable to the throttle body.
