2003 Tranny Issue or CV Axle
Old Oct 29, 2010 | 10:13 AM
pthompson7's Avatar
pthompson7
Default 2003 Tranny Issue or CV Axle
We changed the CV axle and when I turn it by hand, I can feel resistance until a spot where it turns free for about an inch, and then it goes back to having resistance. Not sure if it's related to the CV axle, or the transmission.
Any help will be appreciated.
Old Oct 29, 2010 | 10:20 AM
castlenut's Avatar
castlenut
Where and how are you turning it from?
Old Oct 29, 2010 | 10:48 AM
pthompson7's Avatar
pthompson7
Default Turning from
The transmission end is still in the transmission, and the other end is off the wheel and Im holding it in my hand.
Old Oct 29, 2010 | 12:56 PM
castlenut's Avatar
castlenut
I think thats normal but I'm not sure. I just installed mine and I believe the same thing happens to me. Everything seems to be okay on my install. Maybe someone here can shed some light as to how that actually works. ...
Old Oct 29, 2010 | 02:16 PM
pthompson7's Avatar
pthompson7
So what your saying is that there should be a spot when I turn the CV axle it should have free play in it for about an inch worth of turning, and feel resistance for the remainder of the time. When it drives, with no load on the drive train it's fine, when I put it under a load and try to take off, I get a grinding sound from the drivers side of the vehicle. I just can't figure out what it is? Not sure if it's the CV Axle or the tranny.
