03 Stratus coupe lowering kit
Old Oct 29, 2010 | 12:57 PM
CMBoardman's Avatar
CMBoardman
Default 03 Stratus coupe lowering kit
Which lowering kit rides the best and will be the most durable. Eibach, sprint, or B&G.
The eibach pro lowers it 1.5 front and back and the eibach sportline lowers 2 front and back.
Sprint is 1.8 up front 1.7 in back.
Then the b&g has 1.75 drop front and back.
I figure the more lowered, the more rough the ride is going to be, so pretty much i'm trying to figure out what is going to be the most durable
Old Oct 29, 2010 | 06:31 PM
pearl01stratcpe's Avatar
pearl01stratcpe
I have Eibach Sportline springs. Had them on for almost 40k miles with no issues. The struts are getting to where they are due for a change because of mileage, not because they feel worn out. Always upgrade struts when lowering.
Old Oct 29, 2010 | 09:32 PM
CMBoardman's Avatar
CMBoardman
OK, well i just replaced the struts like 8-10k miles ago. They're straight from daimlerchrysler(wasn't thinking about lowering it at the time), but would they be fine for a while? Or, should I still upgrade them before I lower it?
Old Oct 29, 2010 | 10:06 PM
pearl01stratcpe
Well,its always best to upgrade to something stiffer.I went with the KYB GR2's which are 15% stiffer then stock and I have had no issues at all. Reccomended is the KYB AGX's which are fully adjustable. They have 4 adjust settings.
Old Oct 30, 2010 | 01:59 PM
CMBoardman's Avatar
CMBoardman
okay i looked into it and i don't see any agx struts that fit the 6 or 4 cyl....help? And another question, I have a i4 in mine, do the sxt and r/t have the same suspension? oh and yet another....after I replaced my struts up front the ride was more smooth and a little more quiet, but it still seems to hit bumps harder than when I bought the car....might I possibly need new strut bumpers or...what? I also have 3 loose engine mounts, but that shouldn't make any extra noise over bumps, just slight abnormal vibrations, right?
Old Oct 31, 2010 | 05:16 PM
pearl01stratcpe
Search for the AGX struts under 00-05 Mitsubishi Eclipse. Same chassis. V6 or I4 uses the same suspension. Not sure what could cause it to hit bumps hard.
Bad engine mounts are common, and cost about $100 for upgraded inserts. Bad mounts just add to vibration like you said.
