Grinding noise from manual tranny
Old Nov 14, 2010 | 12:55 AM
RAMKIN326's Avatar
RAMKIN326
Default Grinding noise from manual tranny
I have a 2003 dodge rt 2.7 5 spd and today on my way home the tranny made a grinding noise and wouldn't move when put into gear i tried going into reverse in order to get out of the road but i made the same grinding noise good thing i was down hill and just coasted in to a parking lot. I have been looking online in order to get some ideas of what i t might be and i have come to the conclusion that it might be the throw bearing. I just want i know if my conclusion is right. I know that i will have to change the clutch in the process ant help will be helpful though thank yall
Old Nov 14, 2010 | 01:20 AM
master tech's Avatar
master tech
Site Moderator & Tech
It maybe the clutch that is gone.Can you shift transmission shifter without pushing the clutch? If you can,the clutch is gone.
Old Nov 16, 2010 | 01:55 AM
RAMKIN326's Avatar
RAMKIN326
it makes the grinding noise only when my foot is off the clutch pedal and i dont want to mess the tranny up (if it is already messed up) so i havnt tried to put it into gear after it first started to do that but the clutch had been on the fritz before this so thats y im thinking it the clutch and the throw bearing
(thank you for the reply)
Old Nov 16, 2010 | 11:50 PM
master tech
The grinding sound could be the input shaft bearing. Have you ck the fluid level.
Old Nov 18, 2010 | 01:19 AM
RAMKIN326's Avatar
RAMKIN326
yes it good
