need help with thermostat
Old Jun 9, 2005 | 01:25 PM
hedder24's Avatar
hedder24
Default need help with thermostat
I have a 2002 Dodge Stratus. The thermostat dial has different levels--1, 2, 3 and 4. 1, 2, and 3 don't work but 4 does, which is full blast. What is the problem and is it expensive to fix?
Old Jun 10, 2005 | 03:35 PM
snookdogg2003's Avatar
snookdogg2003
Default RE: need help with thermostat
Had the same problem with my car, but had it fixed while under warranty.
http://autos.msn.com/research/vip/Re...P&tab=6&sub=-1
An occasional problem on this vehicle is failure of the Blower Motor Resistor, 4 door sedan only. Failure of the Blower Motor Resistor may cause the fan to run only on high speed. The cost to repair the Blower Motor Resistor is estimated at $14.75 for parts and $32.50 for labor. All prices are estimates based on $65 per flat rate hour and do not include diagnostic time or any applicable sales tax.
Old Jun 10, 2005 | 03:55 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
when i worked for dodge, i dont think that there was a part more commonly replaced than the blower resistor.
Old Jun 10, 2005 | 04:40 PM
hedder24's Avatar
hedder24
Thanks guys. I appreciate it.
Old Jun 10, 2005 | 06:37 PM
hedder24's Avatar
hedder24
Where is it located? Is it a do-it-yourself project?
Old Sep 15, 2005 | 10:27 PM
rminpeoria's Avatar
rminpeoria
I'd like to know the same thing - my fan just quit working on speeds 1 thru 3 but works on 4. Where is the blower motor resistor located? What steps does it take to replace, i.e. can I do it myself without a lot of knowledge, tools or do I have to take it to the dealership?
Thanks!
Old Sep 16, 2005 | 09:38 AM
thump186's Avatar
thump186
I believe it is replaced all as one unit. I had mine done under warranty service. I also belive there was a tsb on the blower resistor.
