mil codes for 2001 to 2003 ST body
Automatic transaxle (transmission)
dtc p0705: Transmission range switch malfunction
dtc p0712: Transmission fluid temperature sensor malfunction (low input)
dtc p0713: Transmission fluid temperature sensor malfunction (high input)
dtc p0715: Input shaft speed sensor malfunction
dtc p0720: Output shaft speed sensor malfunction
dtc p0731: Gear 1 incorrect ratio
dtc p0732: Gear 2 incorrect ratio
dtc p0733: Gear 3 incorrect ratio
dtc p0734: Gear 4 incorrect ratio
dtc p0736: Gear reverse incorrect ratio
dtc p0741: Torque converter clutch system malfunction (stuck off)
dtc p0742: Torque converter clutch system malfunction (stuck on)
dtc p0743: Torque converter clutch solenoid malfunction
dtc p0753: Shift solenoid-a (low and reverse solenoid) malfunction
dtc p0758: Shift solenoid-b (underdrive solenoid) malfunction
dtc p0763: Shift solenoid-c (second solenoid) malfunction
dtc p0768: Shift solenoid-d (overdrive solenoid) malfunction
dtc p1751: A/t control relay malfunction
engine <2.4l>
dtc p0101: Volume air flow circuit range/performance problem
dtc p0106: Barometric pressure circuit range/performance problem
dtc p0107: Barometric pressure circuit low input
dtc p0108: Barometric pressure circuit high input
dtc p0111: Intake air temperature circuit range/performance problem
dtc p0112: Intake air temperature circuit low input
dtc p0113: Intake air temperature circuit high input
dtc p0116: Engine coolant temperature circuit range/performance problem
dtc p0117: Engine coolant temperature circuit low input
dtc p0118: Engine coolant temperature circuit high input
dtc p0121: Throttle position sensor circuit range/performance problem
dtc p0122: Throttle position sensor circuit low input
dtc p0123: Throttle position sensor circuit high input
dtc p0125: Insufficient coolant temperature for closed loop fuel control
dtc p0128: Coolant thermostat malfunction
dtc p0130: Heated oxygen sensor circuit (sensor 1)
dtc p0131: Heated oxygen sensor circuit low voltage (sensor 1)
dtc p0132: Heated oxygen sensor circuit high voltage (sensor 1)
dtc p0133: Heated oxygen sensor circuit slow response (sensor 1)
dtc p0134: Heated oxygen sensor circuit no activity detected (sensor 1)
dtc p0135: Heated oxygen sensor heater circuit (sensor 1)
dtc p0136: Heated oxygen sensor circuit (sensor 2)
dtc p0137: Heated oxygen sensor circuit low voltage (sensor 2)
dtc p0138: Heated oxygen sensor circuit high voltage (sensor 2)
dtc p0139: Heated oxygen sensor circuit slow response (sensor 2)
dtc p0141: Heated oxygen sensor heater circuit (sensor 2)
dtc p0171: System too lean
dtc p0172: System too rich
dtc p0181: Fuel temperature sensor circuit range/performance
dtc p0182: Fuel temperature sensor circuit low input
dtc p0183: Fuel temperature sensor circuit high input
dtc p0201: Injector circuit malfunction
dtc p0202: Injector circuit malfunction
dtc p0203: Injector circuit malfunction
dtc p0204: Injector circuit malfunction
dtc p0300: Random/multiple cylinder misfire detected
dtc p0301: Cylinder 1 misfire detected
dtc p0302: Cylinder 2 misfire detected
dtc p0303: Cylinder 3 misfire detected
dtc p0304: Cylinder 4 misfire detected
dtc p0335: Crankshaft position sensor circuit malfunction
dtc p0340: Camshaft position sensor circuit malfunction
dtc p0401: Exhaust gas recirculation flow insufficient detected
dtc p0403: Exhaust gas recirculation control circuit
dtc p0421: Warm up catalyst efficiency below threshold
dtc p0441: Evaporative emission control system incorrect purge flow
dtc p0442: Evaporative emission control system leak detected (small leak)
dtc p0443: Evaporative emission control system purge control valve
dtc p0446: Evaporative emission control system vent control circuit
dtc p0451: Evaporative emission control system pressure sensor range/performance
dtc p0452: Evaporative emission control system pressure sensor low input
dtc p0453: Evaporative emission control system pressure sensor high input
dtc p0455: Evaporative emission control system leak detected (gross leak)
dtc p0456: Evaporative emission control system leak detected (very small leak)
dtc p0461: Fuel level sensor circuit range/performance
dtc p0500: Vehicle speed sensor <m/t>
dtc p0506: Idle control system rpm lower than expected
dtc p0507: Idle control system rpm higher than expected
dtc p0551: Power steering pressure sensor circuit range/performance
dtc p1400: Manifold differential pressure sensor
dtc p1603: Battery backup circuit malfunction
engine <3.0l>
dtc p0130: Heated oxygen sensor circuit (bank 1, sensor 1)
dtc p0131: Heated oxygen sensor circuit low voltage (bank 1, sensor 1)
dtc p0132: Heated oxygen sensor circuit high voltage (bank 1, sensor 1)
dtc p0133: Heated oxygen sensor circuit slow response (bank 1, sensor 1)
dtc p0134: Heated oxygen sensor circuit no activity detected (bank 1, sensor 1)
dtc p0135: Heated oxygen sensor heater circuit (bank 1, sensor 1)
dtc p0136: Heated oxygen sensor circuit (bank 1, sensor 2)
dtc p0137: Heated oxygen sensor circuit low voltage (bank 1, sensor 2)
dtc p0138: Heated oxygen sensor circuit high voltage (bank 1, sensor 2)
dtc p0139: Heated oxygen sensor circuit slow response (bank 1, sensor 2)
dtc p0141: Heated oxygen sensor heater circuit (bank 1, sensor 2)
dtc p0150: Heated oxygen sensor circuit (bank 2, sensor 1)
dtc p0151: Heated oxygen sensor circuit low voltage (bank 2, sensor 1)
dtc p0152: Heated oxygen sensor circuit high voltage (bank 2, sensor 1)
dtc p0153: Heated oxygen sensor circuit slow response (bank 2, sensor 1)
dtc p0154: Heated oxygen sensor circuit no activity detected (bank 2, sensor 1)
dtc p0155: Heated oxygen sensor heater circuit (bank 2, sensor 1)
dtc p0156: Heated oxygen sensor circuit (bank 2, sensor 2)
dtc p0157: Heated oxygen sensor circuit low voltage (bank 2, sensor 2)
dtc p0158: Heated oxygen sensor circuit high voltage (bank 2, sensor 2)
dtc p0159: Heated oxygen sensor circuit slow response (bank 2, sensor 2)
dtc p0161: Heated oxygen sensor heater circuit (bank 2, sensor 2)
dtc p0171: System too lean (bank 1)
dtc p0172: System too rich (bank 1)
dtc p0174: System too lean (bank 2)
dtc p0175: System too rich (bank 2)
dtc p0205: Injector circuit malfunction
dtc p0206: Injector circuit malfunction
dtc p0305: Cylinder 5 misfire detected
dtc p0306: Cylinder 6 misfire detected
dtc p0421: Warm up catalyst efficiency below threshold (bank 1)
dtc p0431: Warm up catalyst efficiency below threshold (bank 2)
engine <2.4l>
engine <3.0l>
