spark, fuel, no start?
Old Dec 21, 2010 | 10:59 PM
POStratus's Avatar
POStratus
Default spark, fuel, no start?
2004 dodge stratus 2.4 DOHC timing belt jumped timing, fixed the timing belt, now it wont start, itll crank forever, has spark and has fuel. what could cause this? already changed out the camshaft position sensor
Old Dec 21, 2010 | 11:11 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Have you either replace the spark plugs or remove them to see if they are soaked with fuel?
Old Dec 21, 2010 | 11:14 PM
POStratus's Avatar
POStratus
yeah about 10k miles on the spark plugs, but yes i did pull them and yes they are soaked in fuel
Old Dec 21, 2010 | 11:58 PM
master tech
Let them dry out or replace them. Also try starting with the spark plugs in the motor. This will help getting some of the fuel out.
Old Dec 22, 2010 | 01:19 PM
POStratus's Avatar
POStratus
pulled them out, dried them let them sit in a rag in the house for about 2 hours, put them back in, same problem fuel soaked spark plugs, plenty of spark, and no start...
Old Dec 22, 2010 | 10:12 PM
master tech
Have you done a compression test yet?
