2000 Dodge Stratus Cylinder 1 won't fire
Old Jan 1, 2011 | 03:18 PM
aweaef's Avatar
aweaef
Default 2000 Dodge Stratus Cylinder 1 won't fire
2000 Dodge Stratus 2.4.
Replaced plug and checked plug wire. No spark to cylinder 1. Other 3 are firing. Engine runs rough. Could the coil be bad but run on the 3 other cylinders and not get fire to cylinder 1?
Thanks
Old Jan 1, 2011 | 05:04 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Have you tried another wire from the number 1 coil side?
Old Jan 1, 2011 | 05:09 PM
aweaef's Avatar
aweaef
Thank you.
Yes we switched number 1 and 4 wires but it made no difference. Does this coil have 4 separate coils?
Old Jan 1, 2011 | 07:42 PM
master tech
Then ck the wires that is pluged into the coil pack, and clean the connector if needed. If everything checks out fine,then replace the coil pack.
