2004 stratus rt washer motor
Old Jan 6, 2011 | 01:55 PM
roofus's Avatar
roofus
Default 2004 stratus rt washer motor
I have a 2004 stratus rt sedan windsheild washer is not working. If it is a fuse were would it be and how do you access washer motor? Any suggestions. Thank You
Old Jan 9, 2011 | 12:54 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
DIAGNOSIS AND TESTING - WINDSHIELD WASHERS
Whenever a windshield washer malfunction occurs, first verify that the windshield washer wire harness is properly connected to all connectors before starting normal diagnosis and repair procedures. Refer to the WINDSHIELD WASHER DIAGNOSIS table.
WINDSHIELD WASHER DIAGNOSIS CONDITION POSSIBLE CAUSE CORRECTION
PUMP RUNS NO FLUID FLOWING. 1. NO FLUID IN THE RESERVOIR. 1. FILL RESERVOIR.
2. NOZZLE PLUGGED OR FROZEN. 2. THAW AND CHECK FLOW IF BLOCKED
3. BROKEN, LOOSE OR PINCHED HOSE. 3. CHECK FLOW THROUGH HOSE CONNECTIONS.
4. FAULTY PUMP. 4. APPLY BATTERY VOLTAGE TO MOTOR TERMINALS, REPLACE IF PUMP DOES NOT RUN.
SYSTEM OPERATES INTERMITTENTLY. 1. LOOSE WIRE CONNECTION. 1. CHECK WIRE CONNECTIONS.
2. FAULTY SWITCH. 2. DISCONNECT WIRE HARNESS USE VOLTMETER TO CHECK SWITCH.
SYSTEM OUTPUT IS LOW. 1. PINCHED HOSE. 1. CHECK FLOW THROUGH HOSE CONNECTION.
2. HOSE BLOCKED. 2. DISCONNECT HOSE AT NOZZLE AND Y CONNECTOR. CHECK FOR FLOW. REPLACE AS NECESSARY.
Old Jan 9, 2011 | 11:59 AM
roofus's Avatar
roofus
Default status r/t washer motor
Thanks for info. checked motor . car was in auto body repair shop to get front nose part repaired and they did not plug motor back in.. Thanks Again
