Control Arm Recall?
Old Jan 18, 2011 | 02:13 PM
Dealz4real's Avatar
Dealz4real
Default Control Arm Recall?
The ball joints are bad on my 02 Strat RT. I hear that Dodge recalled control arms because of ball joint failure. Anyone have experiece dealing with this? What years were effected? What was replaced? Thanks!
Old Jan 18, 2011 | 06:54 PM
22DODGE22's Avatar
22DODGE22
http://www-odi.nhtsa.dot.gov/cars/pr...ls/results.cfm
Old Jan 18, 2011 | 10:31 PM
master tech's Avatar
master tech
Site Moderator & Tech
No recall's for ST or JA/JR bodys, only the FJ body and that was for the front lower control arms.
Old Jan 18, 2011 | 10:34 PM
22DODGE22's Avatar
22DODGE22
Make: DODGE Model: STRATUSModel Year: 2002Manufacturer: QUALIS AUTOMOTIVE LLCMfr's Report Date: OCT 08, 2009NHTSA CAMPAIGN ID Number: 09E056000 N/A
NHTSA Action Number: N/A Component: SUSPENSION:FRONT:CONTROL ARM:LOWER BALL JOINT Summary:
QUALIS AUTOMOTIVE IS RECALLING CERTAIN AFTERMARKET BALL JOINTS SOLD FOR USE ON CERTAIN PASSENGER VEHICLES. THE SOCKET MAY HAVE BEEN EXCESSIVELY HARDENED WHICH COULD CAUSE IT TO CRACK NEAR THE RETAINING RING GROOVE ALLOWING THE BALL STUD TO SEPARATE UNDER IMPACT LOAD. THE SUBJECT BALL JOINTS WERE SOLD AS FOUR PART NUMBERS, D10945, D10946, G10945, AND G10946. THE AFFECTED CONTROL ARMS, D10945 AND D10946, ARE STAMPED WITH THE FOLLOWING DATES ON THE BALL JOINTS: 134308, 135708, 100109, 102709, 104109, 105509, 107609, 108909, 110309, 113209, AND 116609. THE G10945 AND G10946 ARE THE SAME PART AS THE D10945 AND D10946 RESPECTIVELY. THEY ARE LABELED DIFFERENTLY DEPENDING ON THE AFTERMARKET CUSTOMER.Consequence:
SEPARATION OF THE BALL STUD FROM THE SOCKET OF THE BALL JOINT HOUSING WOULD ALLOW THE CONTROL ARM TO COLLAPSE AND THE WHEEL TO FOLD IN CAUSING LOSS OF STEERING CONTROL, POSSIBLY RESULTING IN A CRASH.Remedy:
QUALIS AUTOMOTIVE WILL REPLACE THE BALL JOINTS FREE OF CHARGE. THE SAFETY RECALL BEGAN ON NOVEMBER 9, 2009.Notes:
THIS RECALL ONLY PERTAINS TO AFTERMARKET BALL JOINTS AND HAS NO RELATION TO ANY ORIGINAL EQUIPMENT INSTALLED ON VEHICLES PRODUCED BY CHRYSLER. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV . Check to Request Research. Submit below. Make: DODGE Model: STRATUSModel Year: 2002Manufacturer: FEDERAL-MOGUL CORPORATIONMfr's Report Date: DEC 23, 2010NHTSA CAMPAIGN ID Number: 10E059000 N/A
NHTSA Action Number: N/A Component: SUSPENSION:FRONT:CONTROL ARM:LOWER ARM Summary:
FEDERAL-MOGUL IS RECALLING CERTAIN REPLACEMENT CONTROL ARM ASSEMBLIES, PART NUMBERS K7425, 10945, FA4510X, K7427, 10946, AND FA4611X, SOLD FOR USE ON VARIOUS PASSENGER VEHICLES LISTED ABOVE. THE BALL JOINT ON THE CONTROL ARM ASSEMBLY CAN FAIL CAUSING THE BALL STUD TO WEAR THROUGH THE CONTROL ARM HOUSING RESULTING IN NOISE AND/OR SEPARATION OF THE BALL STUD FROM THE HOUSING.Consequence:
IF THERE IS A SEPARATION OF THE BALL STUD FROM THE HOUSING, THE DRIVER CAN LOOSE STEERING CONTROL, POSSIBLY RESULTING IN A VEHICLE CRASH.Remedy:
FEDERAL-MOGUL WILL NOTIFY OWNERS OF RECORD AND REPLACE THE AFFECTED CONTROL ARMS FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN DURING JANUARY 2011. OWNERS MAY CONTACT FEDERAL-MOGUL AT 1-877-489-6659.Notes:
THIS RECALL ONLY PERTAINS TO REPLACEMENT CONTROL ARM ASSEMBLIES AND HAS NO RELATION TO ANY ORIGINAL EQUIPMENT INSTALLED ON VEHICLES MANUFACTURED BY CHRYSLER LLC. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV . Check to Request Research. Submit below. Make: DODGE Model: STRATUSModel Year: 2002Manufacturer: QUALIS AUTOMOTIVE LLCMfr's Report Date: OCT 08, 2009NHTSA CAMPAIGN ID Number: 09E056000 N/A
Old Jan 18, 2011 | 10:39 PM
hemi4spd's Avatar
hemi4spd
so if your BJ's are OEM theres no recall
why i only use MOOG chassis parts
