oil in coolant
Old Feb 5, 2011 | 04:32 PM
shadow1100sc's Avatar
shadow1100sc
Default oil in coolant
1999 Dodge Stratus w/ 2.4 Coolant pooring out from passenger side I assume its a water pump. But has oil in resevoir. and when i filled it to see where it was coming from you could see that the oil was starting to get into the coolant again. Where is the oil coming from ?
Thanks
Old Feb 6, 2011 | 01:49 PM
FrankTA2's Avatar
FrankTA2
Default oil & coolant mix
Usually that means a head gasket leak.
Old Feb 6, 2011 | 02:43 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
It could from a couple of places, first like frankta2 had said head gasket. another way is from the radiator. Transmission fluid.
Old Feb 13, 2011 | 11:12 AM
GALVANIZEDYANKEE's Avatar
GALVANIZEDYANKEE
Check to see what the oil on the dip stick look like. If it is milky you probably have a head gasket leak, or a cracked block. If it is just the overflow bottle it can also be the head gasket, but the oil on the dip stick looks normal. You can pressure test the cooling system to see if it holds pressure. With a leaking water pump it definitely won't hold pressure. In either case I would suspect the head gasket is blown and allowing compression to be blown into the cooling system.
