NEED HELP- Dodge Stratus
Old Feb 10, 2011 | 06:02 PM
Beerman52356's Avatar
Beerman52356
Default NEED HELP- Dodge Stratus
I recently bought a 98 dodge stratus 2.4l, and had no problems til the other day on my way to work the lights got dimmer and the dash lights finally went out and the call stalled. I thought Alternator and removed it and had it tested, to my supurise it was just fine, then the battery light has been comming on and i took out the battery and had it tested it was fine just low charge, so charged it up and still having battery light come on and gaguages getting dim.... any help on what else I am missing?? thanks
Old Feb 10, 2011 | 08:50 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the Stratus section,
FF
Old Feb 10, 2011 | 09:16 PM
22DODGE22's Avatar
22DODGE22
Wiring or PCM problem? That would be my guess since you apparently eliminated the other 2 obvious things (alt and battery)
Old Feb 11, 2011 | 01:58 PM
ratsttam's Avatar
ratsttam
Check that all the grounds are good. If either the battery or the alternator grounds are bad, worn, or even just loose, it's as good as not being connected at all. Since the car STARTED, I would say to focus on the alternator ground points. Disconnect, clean, and replace as necessary.
Old Feb 11, 2011 | 10:46 PM
master tech's Avatar
master tech
Site Moderator & Tech
Have you had the charging system checked with engine running?
Old Feb 12, 2011 | 11:28 AM
Beerman52356
Default 98 stratus
Honestly i am just a backyard mechanic and have no clue how to check charging system
Old Feb 12, 2011 | 02:11 PM
22DODGE22's Avatar
22DODGE22
Even a backyard mechanic knows how to check a charging system, all you need is a $2.99 electrical test meter.
