help please tell me what no bus means
Old Mar 22, 2011 | 01:27 PM
doctor_green_thumbs's Avatar
doctor_green_thumbs
Default help please tell me what no bus means
i have a 2006 dodge stratus and now my power locks and dome light and stereo stopped working and its says no bus after i take my keys out please help me and let me know what i need to do thank you
Old Mar 22, 2011 | 03:12 PM
rmckellar's Avatar
rmckellar
Sounds like the body control module (BCM) may be offline. Check all your fuses. Have you installed any aftermarket non-OEM electronics?
Old Mar 23, 2011 | 01:09 PM
doctor_green_thumbs
why yes i did tried to put in an after market stereo in my car but even when i put the stock back in it still does not work
Old Mar 23, 2011 | 02:41 PM
doctor_green_thumbs
o yeah i check all my fuses and they are all good in side and out side are all good
Old Mar 23, 2011 | 10:09 PM
master tech's Avatar
master tech
Site Moderator & Tech
The dome lite and radio share the IOD fuse. Did you try installing radio with the battery still connected?
Old Mar 24, 2011 | 05:36 AM
doctor_green_thumbs
yeah but i check all my fuse's i have had 2 other people look at all my fuse's
Old Mar 24, 2011 | 10:21 AM
ratsttam's Avatar
ratsttam
Try this. Pull the IOD fuse out for 5 minutes. This will force all your onboard computers to reset. This a lot of times fixes other "odd" minor electrical issues too. If you are still getting the "no bus" error, the bus wire may be damaged, disconnected (just about everything in a modern car talks to every other component), or you may have a larger issue where one of the computers have failed.
Old Mar 24, 2011 | 04:42 PM
doctor_green_thumbs
do you know where its at no for sure where its at
