Crankshaft Position Sensor
Old Mar 22, 2011 | 08:44 PM
JohnnyRebs360's Avatar
JohnnyRebs360
Question Crankshaft Position Sensor
where is this sensor on a 1995 Cirrus with a Mittsibishi 2.5 v6 [6g73]?
how to test this sensor?
Old Mar 22, 2011 | 09:01 PM
bad venge's Avatar
bad venge
Section Moderator
https://dodgeforum.com/forum/diy-do-...bad-venge.html
Old Mar 22, 2011 | 09:28 PM
JohnnyRebs360
Hey man thanks, but my battery is inside the front fender
where is the sensor bolted to the trans or engine?
Old Mar 22, 2011 | 09:38 PM
bad venge's Avatar
bad venge
Section Moderator
should be 12:00 under the distro unsure on your vehicle
Old Mar 23, 2011 | 06:53 AM
22DODGE22's Avatar
22DODGE22
The crank sensor is in the transmission bellhousing directly below the rear cylinder head which would be approx the 1:00 position when looking at the trans standing at the driver side fender. if you put your 2 feet next to the Left Front tire, looking at the transmission, that 1:00 position (This is if you are familar with analog clocks)
