2004 Dodge Stratus....No radio,dome light or door lock power
Yesterday i put an aftermarket radio in my car.all the connections were right but it still kept blowing a fuse.after 2 tries i gave up and put the stock radio back in.After i did that i noticed that my power locks,radio, or my interior dome lights wont come on.i checked the fuse box located next to the stering wheel and replaced the blown one and still nothing..im bummed out now LOL.any help or advice would be greatly appreciated.
I am hoping to get this same info for mine. I herd if you disconnect the battery then connect the cables together it will reset the unit im going to try and let you know if that works. no need in both of us messin up our cars.
Have you used a 12v test light and check the fuses? Also check the trunk release for power and ground. If you have none, Remove the lower panel and check to see if the release button is plug in. And is your radio factory or aftermarket?
