2000 Stratus Transmission
Old Mar 26, 2011 | 09:12 PM
Bluemach1's Avatar
Bluemach1
Default 2000 Stratus Transmission
I need a little help.
My sons 2000 Stratus ES has transmission issues. It has no reverse and no 4th gear.
I am pulling error codes P0700, P0733, P0736 and P1790. I believe that these codes are indicative of major internal issues.
Am I correct in my assumption? Is it time for a new trans or can there be other issues that may be easier and cheaper to fix?
Thanks!
Old Mar 26, 2011 | 10:18 PM
bjr1a's Avatar
bjr1a
I would disconnect the 8 pin connector next to the fill tube and place gear selector in reverse...if still no reverse,yes its time to remove and repair....
Old Mar 26, 2011 | 10:36 PM
22DODGE22's Avatar
22DODGE22
Problem is most likely the reverse input clutches. my stratus had no 3rd gear, I pulled it fixed the problem for under $50 (broken part).
Old Mar 27, 2011 | 08:56 AM
22DODGE22's Avatar
22DODGE22
You probably have burned up reverse input clutches. A hydraulic pressure test on the Reverse input clutch would show if you are having application.
Old Mar 27, 2011 | 05:21 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I would agree with the other members, the problem is inside the transmission. You would either need to take it apart and inspect what you need to repair the problem or replace the transmission with a reman.
Old Mar 27, 2011 | 05:51 PM
Bluemach1's Avatar
Bluemach1
Thanks for the input. The connector that you are talking about, is it sort of behind / under the air box? There are actually two there. Which one should I be pulling?
Old Mar 27, 2011 | 06:04 PM
Bluemach1's Avatar
Bluemach1
ok, pulled the 8 pin connector off the shift solenoid. still no reverse.
Any recommendations for a good auto trans remanufacturer??
Thanks,
Ted
Old Mar 27, 2011 | 09:09 PM
22DODGE22's Avatar
22DODGE22
It's going to need a rebuild. look into a used trans, or find someone to rebuild the current one. It's quite a job to pull this trans. I did mine about 4 months ago and it took a lot of work
Old Mar 28, 2011 | 10:17 AM
armaniEfiftyfive's Avatar
armaniEfiftyfive
Just curious how many miles? Was tranny ever flushed/and refilled with new tanny oil?
Old Mar 29, 2011 | 06:17 PM
Bluemach1's Avatar
Bluemach1
The car has about 130k on it. As far as I know, it has never had a flush or fluid change.
Can anyone recommend somewhere to buy a remanufactured trans from??
Thanks,
Ted
