Steering wheel viberation and engine Grrrr
Old Mar 29, 2011 | 10:45 AM
JSTJ704's Avatar
JSTJ704
Default Steering wheel viberation and engine Grrrr
I need some help my steering wheel viberates at idle goes away when I give it gas so does the engine. The car starts right up runs and drives get but has a viberation at idle. I'am lost tryed everything that I know of.
Sensors
Idle sensor
cam and crank sensor
air sensor
tps tested good
Full tune up
Plugs wires etc
Fuel
New pump and filter and removed injectors cleaned and tested OEMS.Cleaned throttlebody
engine
replaced all mounts but the tranny mount
I check the intake for leaks with carb cleaner too
Anyone have any idea it's driving me crazy!
thanks Justin
Old Mar 29, 2011 | 11:02 PM
master tech's Avatar
master tech
Site Moderator & Tech
Do you know what your vacuum is at an idle?
Old Mar 29, 2011 | 11:47 PM
JSTJ704's Avatar
JSTJ704
I'sm not sure what my vacum is at idle how do I check that?
Old Mar 30, 2011 | 12:50 AM
master tech
Hook up a vacuum gauge to a port that has vacuum at it.
Old Mar 31, 2011 | 03:24 PM
JSTJ704's Avatar
JSTJ704
Master tech I notice it more in drive then park. Could it be my tranny mount. The engine doesn't viberate as bad as the steering wheel could it be power steering pump or power steering pressure switch.My steering is kinda stiff I noticed. I was under the car today jacked up with the engine running I felt the rack,on the pass side I felt no vib. On the drive side were the steering shaft mount to the rack I could feel vib there.
Old Apr 2, 2011 | 11:26 AM
master tech
You maybe on to something, Let us know what you found.
