04 STRATUS SEDAN 5speed Clutch issues!
Old Apr 3, 2011 | 02:16 PM
hemis4two's Avatar
hemis4two
Default 04 STRATUS SEDAN 5speed Clutch issues!
The issue I'm having is that the clutch will not completely disengage. I need to know what to do to figure out what may be the problem and if anyone has any experience with them. Is there any adjustment??? Please help!
Old Apr 3, 2011 | 09:22 PM
master tech's Avatar
master tech
Site Moderator & Tech
The clutch system is a hydraulic and there isn't any adjustment. Has the clutch system been worked on?
Old Apr 3, 2011 | 10:11 PM
hemis4two's Avatar
hemis4two
It has not been worked on to my knowledge. We got it used in 06 with like 15000 miles on it or so. It hasn't been right for a while now. The hardest gear is 1st, sometimes you really have to jam it in and other times it's not so dificult. At a stop with the pedal to the floor and car in gear, you can feel it shuttering unless you put it in nuetral. I was hopeing it could be something easy, but something tells me this is gonna be a pain in the A$$. Where should I start???
