Transmission Gasket Replacement
Old Apr 8, 2011 | 12:54 AM
mrossett's Avatar
mrossett
Default Transmission Gasket Replacement
i have a 2000 Dodge Stratus and wanting to replace my transmission gasket for the third time... i am having trouble knowing how to torque or proper way of replacement of the gasket ... maybe i am missing something.... after installation the gasket begins to leak.. need help please wanting to know if i need to use a torque wrench or cross pattern
e
Old Apr 9, 2011 | 12:12 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Are you using the RTV for transmissions or a pan gasket? The torque is 12 ft pounds. Also you need to clean out all bolt holes the have silicone in them. Or you can damage the case.
Old Apr 15, 2011 | 10:02 PM
armaniEfiftyfive's Avatar
armaniEfiftyfive
The issue your having is with the pan itself. The pan bolts can easly be over torque. I just went through this. I had to do the tranny pan twice and the 2nd time is what it took to prevent the leaks. Go to rockauto. Also the new tranny pams have a bolt to flush the tranny. Pick up the gasket and also use rtv.
GL
