2005 Dodge Stratus A/C will not come on along with radio.
Old Apr 16, 2011 | 08:39 PM
hfwings's Avatar
hfwings
Default 2005 Dodge Stratus A/C will not come on along with radio.
I just bought this car and the ac will not power along with the radio.
What will I have to look for?
A book did not even come with the car ): Please help..
Old Apr 16, 2011 | 10:19 PM
BillS's Avatar
BillS
try checking fuses on an '04 the blower motor is #1,radio #14;there are 2 fuse boxes 1 under hood(driver side ),one in dash on drivers side(panel pulls off) when you open door , should have what each fuse is for printed on panel
Old Apr 17, 2011 | 11:47 AM
hfwings's Avatar
hfwings
All the fuses check out ok and the 30 amp blower fuse and still no power to the radio and ac.
What is my next step in trying to repair this.
Old Apr 17, 2011 | 01:21 PM
BillS's Avatar
BillS
you can try taking radio out ,to see if theres power at the connector,if you have 10 pin connector check pin 5 with key on ;pin 10 should have power either on or off. if you have 22 pin check pin 2 key on,pin 12 power on or off. looking at the connector with the clip on top 1 is on left(10 pin 1-5 top, 6-10 bottom row; on 22 pin 1-11 top, 12-22 bottom row). might be problem with body control module not communicating,try having it checked for codes
Old Apr 17, 2011 | 06:00 PM
hfwings's Avatar
hfwings
I remove the panel and guess what? No connection to the ac control unit at all.
I plug it in and ice cold she gets and the radio was unplug also and plug it in also and bang...
Bought this car for 3850.00 with 85000 miles on it... what a deal I got in Atlanta..
