Just purchased a '97 Strat ES
Old Apr 22, 2011 | 06:48 PM
RangoStar's Avatar
RangoStar
Default Just purchased a '97 Strat ES
After selling my 1996 Stratus base earlier this year and with rising gas prices, was time to start looking for a commuter car.
Found a one owner since new 1997 Stratus ES V6 with 87000kms (54000 miles), white with a bit of rust on the rockers and on the hood. Has what an ES comes with, although, there is no keyless remote, can I buy one and program it myself?
Suspension is rock solid, that V6 is very smooth and responsive. ABS and E-brake light is on, what could that be?
Also, i'm not very familiar with that V6, is there anything I should do or be on the watch for?
Old Apr 23, 2011 | 02:13 PM
GALVANIZEDYANKEE's Avatar
GALVANIZEDYANKEE
The 2.5 is a Mitsubishi engine. It is prone to valve cover gasket leaks as well as spark plug tube leaks.
The power door locks were original equipment. Weird, remotes and alarm were an option.
Yes, you can easily add an aftermarket remote if you can read schematics.
Having owned an96 Stratus you are probably aware that the front and rear upper ball joint require lubrication every 30,000 miles.
Old Apr 24, 2011 | 09:04 PM
RangoStar's Avatar
RangoStar
Thanks,
Valve covers and tubes, done that on my Neon, so it should be a fairly easy job to do. As long as it's not something like the headgakets...
Always lubricated the upper balljoints.
At that mileage, I wouldn't think anything related to the suspension should wear out anytime soon.
