TCM pins 15,16,17 no 12 volts
Old Apr 23, 2011 | 02:03 PM
ledsd's Avatar
ledsd
Default TCM pins 15,16,17 no 12 volts
1995 dodge stratus es
6 vin H
transmission in limp mode
no code
replace solenoid pack and tcm relay
checked all wiring....good
no 12 volts on pins 15, 16, 17
15 is supply voltage
16/17 output
14 output speed
13 common I/O speed
52 input speed ...reading to ground????
outside that all is good
after install of sol-pac and tcm relay, test drive car changed out and then back to limp
at moment rpm is 30 and speed is 20 to 30
question: is this bad tcm or pcm or need flashing update
question: will 2001 transmission fit in 95
any help thanks
Old Apr 23, 2011 | 06:47 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Did you ck the 12 volts going to the TCM relay and does it have 12 volts? You should have stored codes in the TCM.
Old Apr 23, 2011 | 09:22 PM
ledsd's Avatar
ledsd
no codes
yes voltage at tcmr at contact side key on/off
reading with tester to harness and to tcm pin
12v on pin 56/11 key off / on
key on/off....no volts on pin 15... supply voltage 12 volts..controls coil on tcmr to allow voltage to pass to sol pac
pin 52 is reading to ground...harness wiring...it is input to tcm from input speed sensor
pin 14 reads good..no short...input from output speed sensor
pin 13 is common to both i/o speed sensors and should read to ground not 52
it seems to fail to pass supply power..15.. to tcmr to close coil to allow volts pass..16/17.. to sol pac
will double check finding tommorrow
but still no code...it is the flashing engine light
only 12 and 55
Old Apr 23, 2011 | 09:29 PM
atthewmartin114's Avatar
atthewmartin114
pcm is no good its internally shorted out. i just had a stratus. in the shop about a month ago same issue. we thought the wires were broke so we got a wip and installed it and still the same issue. then we flashed the pcm no change. i took the pcm from another stratus on the lot and bamm issue gone. so we ordered a new one flashed it and away it went.
tho it is very possable that you have a shorted sensor and its back feeding or a bad graound that back feeding so dont rule out wiring just yet.
Old Apr 23, 2011 | 09:41 PM
ledsd's Avatar
ledsd
my understanding is if key on then 12v at 15...16...17
i have schematics and book on transmission
if i am not getting volt on 15, a supply, the there must be something denying it.
i would think it should be there.unless internal fault on tcm some sensor telling it to not send supply..highly unlikely...lol...im thinking some AI crap now..lol
ign on pin 8 has 12
im leaning toward tcm
all other checks out
no codes
voltage there
wiring good
and thanks for the welcome
Old Apr 23, 2011 | 09:48 PM
ledsd's Avatar
ledsd
thanks im gona try that tommorow
pcm...tcm...what ever happened to the simple little brain thingie in your dist...lol
Old Apr 24, 2011 | 11:21 AM
ledsd's Avatar
ledsd
new test today
voltage is on pin 15 ..had to test with relay in...car running
still dropping in limp n mode
all wiring harness wire good... no grounds..except those that are suppose to
all pins that are in tcm for ground are properly working
all pin on harness for 12v is good..car off, on, run
received code 66 pcm fail to read tcm
could this be tcm need flash..reprogram
Old Apr 24, 2011 | 03:27 PM
atthewmartin114
reprogram the TCM and you should be good. if not the tcm needs to be replaced
Old Apr 25, 2011 | 08:29 PM
ledsd's Avatar
ledsd
droped car off at dealer to run diagnostic on pcm and tcm.
also gona update and quick train pcm and tcm
fingers crossed
and thanks all
Old Apr 26, 2011 | 06:47 PM
ledsd's Avatar
ledsd
dropped car off at dealer and ran diagnostic
will have all code tommorrow ..but for now it looks like its a transmission..so said the dealer
tcm will not reprogram....tmmm sounds like a bad tcm to me...but what do i know
ll i know is the transmission was working fine till it dropped into limp mode
not sure if they updated pcm ..know tommorow
what you think
