Last edit by: IB Advertising
Browse all: Exterior
- Dodge Ram 2nd, 3rd, 4th Gen How to Unclog Windshield Sprayer
Step by step instructions for the do-it-yourself repairs.
2003 Stratus sedan water leak
On my wife's Stratus I pulled out the passenger seat and all the carpet front and rear and hung it up to dry; then I sprinkled baking soda on the jute material and let it sit for about a week before I vacuumed it up. Since I made the fix to the drain around October, I have yet to find out if it is draining properly since we haven't run the AC here in the Northeast.
It's really a shame that Dodge didn't offer a recall for the problem.
I went out and looked at it some more. I noticed that the floor directly under the drivers seat was also pretty wet. Is it possible the drain is plugged up and the moisture is traveling down the vent tube that goes under the console and dumps under the seats? I need to go check and see if the floor under the passenger seat is wet.
Also is there a way under the carpet for the water to get to the front floor from under the seat? If so, I think I know where it is coming from!!
Jeff
Jeff
The water was coming in because the AC drain was not draining to the outside. Instead, it was coming in on the passenger side just below the AC/Heater box allowing water to flood the front and rear... it could also make the drivers side wet as well.
I've made the fix by getting alternate drain tubes but have yet to find out if it works since we have not run the AC yet.
there is a technical service bulletin a revised drain tube ,that might help it has pictures that usually don't show up the right way on here if you want you can send me your email and i'll send them.Raise the vehicle on an appropriate hoist.
8.Remove the HVAC drain tube from the dash panel by squeezing and pulling on the tube near the dash panel..Install drain tube adapter, p/n 05191188AA, onto the HVAC drain nipple, (Fig. 1).
10.Install the revised drain tube, p/n 05264688, onto the drain tube adapter so the down tube is positioned at 7 o'clock when looking toward the rear of the vehicle.
11.Seal the opening in the dash panel where the HVAC drain tube passes through with RTV sealer, p/n 82300234.
12.Lower the vehicle.
Thanks
sorry don't have that picture anymore, my computer died that I had it on, no longer have my stratus, its an easy job think the way they worded tsb was to complicated, the drain is right behind and above the front cross member on firewall , where the drain is, they consider that the dash panel
BillS is correct... it is an easy job for the most part. I did two cars with the kit you can order from the dealer. Basically, you remove the drain tube and insert a longer one and redirect it to drain outside the car. Both of the Stratus's I've done have been fine. Wish I still had the instructions to send you.
My wife's car has developed this problem when it rains.Drivers side floor get soaked.Parking out front of my house is on a slope and if I turn the car aound with left side facing up hill the floor stays dry and water seems to collect on the plastic at bottom of door frame and run outside of vehicle.Possible door seal issue?
