99 Stratus 2.4L Code Error P0352
Old Apr 30, 2011 | 06:54 PM
AKammrad's Avatar
AKammrad
Exclamation 99 Stratus 2.4L Code Error P0352
We are a Dodge Family...but we have become seriously frustrated with our 99 Stratus.
Check Engine light came on, while passing at 80 mph.
When read out, we get code p0352.
We have replaced the coil, still have error code and engine misfire, we replaced the cam sensor, and we still have the same error code and misfire.
We have 130.00 in parts already, with no fix. HELP!
Thanks in advance...
AKammrad
Old May 1, 2011 | 11:09 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I do have some pdf file that may help you. You could have an open circuit or a problem with the PCM. If would like the pdf file, either post your email address or send me a pm.
Old May 2, 2011 | 03:51 AM
AKammrad's Avatar
AKammrad
kammrad@mchsi.com
Old May 29, 2011 | 06:38 PM
AKammrad's Avatar
AKammrad
We have solved the problem finally! The PCM was shot, took days of testing wires and components to resolve the issue.
Old May 29, 2011 | 10:24 PM
master tech
Good job! Glad to hear you found the problem.
Old May 30, 2011 | 12:06 PM
AKammrad's Avatar
AKammrad
And Thank you for the helpful PDF file, master tech, it was a big help in the diagnosis venture!
