2000 stratus es transmission problems
Old Jun 8, 2011 | 01:31 AM
2000ws9's Avatar
2000ws9
Default 2000 stratus es transmission problems
Hi guys i have searched hours trying to find a solution for the problem with my stratus but even the local shops don't have a solution...heres the issue my car makes a medium to heavy vibration when driving and coasting almost like a winding down vibrate sound,BUT when i turn the wheel to the right or make right hand turns it nearly or completely will go away.i am completely baffled as is 3 local shops who have test driven it and tried to troubleshoot it.ANY help will be greatly appreciated. thanks
Old Jun 8, 2011 | 12:35 PM
ratsttam's Avatar
ratsttam
If it's in direct relation to speed, it could be as simple as a worn wheel bearing, possibly a CV joint. Make sure your calipers are secure and no warped rotors.
I don't think it would be the transmission, as that should not change at all by turning.
Old Jun 8, 2011 | 12:37 PM
ratsttam's Avatar
ratsttam
I would also consider checking the power steering rack and pump, although that should make more noise the further you turn...
