i have an 03 stratus put in a reman motor 2.7 it turns over but will not start. starter and battery are new. The scanner says iat too high. It has fuel pressure but only two injectors pulsate. I switched the injectors and if I switch them they work. Checked for spark and only two spark plugs work. Changed each coil around and they all work. The engine is in time. Any help will be appreciated I am frustrated.
