2000 2.4L no spark, no start, new owner. Please help!
Subscribe
Jun 21, 2011 | 09:51 PM
In an attempt to get into a vehicle inexpensively I purchased a non running 202K mile 1 owner 2000 Dodge Stratus that the owner thought had a faulty fuel pump and had been sitting for about a year. Had no fuel at schraeder valve although fuel pump was operating. Dropped tank and saw that it had original filter so replaced it. We now have approx. 50 psi while cranking. Sounds like it fires occasionally when we spray starting fluid in throtle body but never succeeds in starting and we see no indication of spark when this happens with our spark tester. Tested the tester on another vehicle and works fine. Emits some gray stinky smoke from tail pipe. Removed top of timing chain cover and belt turns while cranking engine so doesn't appear broke. Battery seems fine. Holds good charge. Fresh fuel. One cylinder wire was immersed in oil which I am told is probably a valve cover gasket leak. Fuses look fine. Just no spark while cranking on the Stratus. Spark plugs don't seem to be wet as I would suspect if fuel was getting in the cylinder but not firing. Sorry for the length of this but trying to list everything we tried. Thanks in advance for any assistance.
Reply 0
Jun 21, 2011 | 11:03 PM
Welcome to DF
Have you check the wire harness going to the crank sensor? Or the sensor.
Reply 0
Jun 22, 2011 | 07:45 AM
Thanks for the reply. No we haven't. Can you give me a hint as to what to look for and how to check?
Reply 0
Jun 23, 2011 | 03:31 PM
Update - Still waiting on response. Don't know how to check crank sensor. I did check injectors and it appears they are firing using a simple light tester. Approx. 11 volts to each of 3 wires to coil pack during cranking, none with key off.
Reply 0
Jun 24, 2011 | 12:44 AM
The crank sensor is above the oil filter and just below of the alt.
Reply 0
Jun 24, 2011 | 08:02 PM
Thanks for your help! We found step by step diagnostics here http://easyautodiagnostics.com/ and after repair of the wiring harness and replacement of the crankshaft sensor, it started. The step by step diagnosis on the above website is by far the best I can imagine but thanks to master tech for directing me where to look. Until the next failure, have a great summer!
Reply 0
Subscribe
