Air Filter
Old Jul 14, 2005 | 02:33 AM
zairazstratus02's Avatar
zairazstratus02
Default Air Filter
Ok I have to change the Air filter on my wife's 02 stratus 2.7. I figured it would be as simple as a few clips and make the switch. After looking at the air box it does not seem that simple. I didnt have time to mess around but can someone tell me what needs to be done? Unfortunetely i dont have the owners manual.
thanks
Old Jul 14, 2005 | 11:39 AM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default RE: Air Filter
hmm..i do not know where the air box is on her car, but we have a member here with a 2.7 stratus, and have PM'ed him about reading this,and if he doent reply, ill do some looking around for you.
Old Jul 14, 2005 | 08:35 PM
zairazstratus02
ORIGINAL: BadStratRT
Well the filter box is on the Right side very front.
The tubing connected to the air box says check owners manual for air filter. Do you know where i can find a online manual to look at? thanks for any help!
Old Jul 14, 2005 | 08:49 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
there should be 4 snap down connectors...maybe five...one on each side, with possibly two on one side. but i am going by what my car has, which is a 3.0 stratus.
Old Jul 15, 2005 | 01:32 AM
thump186's Avatar
thump186
the easiest way i found to do it is to loosen the clamp at the throttle body and take it off of it , disconnect the hose from the tube, push in on the two tabs holding the filter base to the air box and pull back if done correctly you will see the filter inside the air box.
