00 stratus 2.4L turns wont fire
Old Jul 16, 2011 | 11:33 AM
thom1952's Avatar
thom1952
Default 00 stratus 2.4L turns wont fire
00 stratus stopped running in traffic towed home. Turns, won't fire. Replaced timing belt, tensioner, crank&cam sensors 5000 mi ago. Need to get it running or will lose job.
Old Jul 16, 2011 | 04:27 PM
master tech's Avatar
master tech
Site Moderator & Tech
First of all, do you have spark at the plugs and fuel pressure. If you have both, then do a compression test. Then post your finding.
Old Jul 17, 2011 | 12:33 PM
thom1952's Avatar
thom1952
I have spark I'm not equipped for fuel pressure or compression tests. It was running fine.just stopped in traffic.
Old Jul 17, 2011 | 10:31 PM
master tech
If you have spark, You could have a fuel problem. But this only a guess without seeing the car.
