Annoying rattling in interior
Old Aug 3, 2011 | 12:56 AM
bladex10's Avatar
bladex10
Default Annoying rattling in interior
When i put the car drive, this weird higher pitched rattling noise comes from the driver side of the interior. Its very annoying and i cant pinpoint it. Any idea what it would be? Also when im driving and every time i get up to 2000ish rpms, I get this weird vibration rattle in the middle of the dash from the radio area.
Also, i'm getting alot of vibrations from the car when the ac is on and in drive while braking. Like it vibrates enough to shake the mirrors and the steering wheel but as soon as i let off the brake and let it roll, it goes away. I checked the passenger side motor mount and it looked ok, wasnt broken or destroyed at all. I replaced the plugs and cleaned the iac and map sensor and cleaned the throttle body. What else is there to do to stop this annoying vibration?
Old Aug 4, 2011 | 12:02 AM
master tech's Avatar
master tech
Site Moderator & Tech
Has there been any work done on the timing belt?
Old Aug 4, 2011 | 01:49 AM
bladex10's Avatar
bladex10
Timing belt looks like its been changed once upon a time
Old Aug 4, 2011 | 09:53 AM
master tech
Check the exhaust, see if its hitting the sub frame.
