Fuel Pump Gasket/O-Ring
I dropped my tank on my 2000 Stratus to replace fuel pump with a used one from a junk yard. I was wondering if someone could tell me tell me how the gasket/o-ring goes on so I get a tight seal. If someone has pictures that would be helpful too. Thank you for your help.
Welcome to DF
Here is some information that may help.
FUEL PUMP MODULE
WARNING: RELEASE FUEL SYSTEM PRESSURE BEFORE SERVICING FUEL SYSTEM COMPONENTS. SERVICE VEHICLES IN WELL VENTILATED AREAS AND AVOID IGNITION SOURCES. NEVER SMOKE WHILE SERVICING THE VEHICLE.
REMOVAL
Remove fuel filler cap and perform Fuel System Pressure Release procedure.
Disconnect negative cable from auxiliary jumper terminal.
Remove fuel tank, refer to the Fuel Tank removal section.
Disconnect fuel filter lines from fuel pump module.
Clean top of tank to remove loose dirt and debris.
Using Special Tool #6856 Fuel Pump Module Ring Spanner, remove locknut to release pump module Fuel Pump Module Locknut
WARNING: THE FUEL RESERVOIR OF THE FUEL PUMP MODULE DOES NOT EMPTY OUT WHEN THE TANK IS DRAINED. THE FUEL IN THE RESERVOIR MAY SPILL OUT WHEN THE MODULE IS REMOVED.
Remove fuel pump module and O-ring from tank Fuel Pump Module Removal Discard O-ring.
INSTALLATION
Wipe seal area of tank clean. Place a new O-ring on the ledge between the tank threads and the pump module opening.
Position fuel pump module in tank. Make sure the alignment tab on the underside of the pump module flange sits in the corresponding notch in the fuel tank
CAUTION: Over tightening the pump lock ring may result in a leak.
While holding the pump module in position, install locknut. Tighten locknut to 74.5 N·m (55 ft. lbs) torque using special tool #6856.
Install fuel tank and fuel filter, refer to the Fuel Tank installation section.
Install negative cable to auxiliary jumper terminal.
Fill fuel tank with clean fuel.
FUEL PUMP MODULE
REMOVAL
INSTALLATION
