'03 Stratus R/T sport Transmission problem?
Old Aug 24, 2011 | 09:24 PM
_sleepyd's Avatar
_sleepyd
Default '03 Stratus R/T sport Transmission problem?
Hello, everyone.
My 03 stratus makes a semi violent sounding transition when shifting from reverse to drive only (automatic trans). From park to reverse: nothing concerning. From park to drive: nothing concerning. From reverse to drive: a violent shake/noise.
It doesn't exactly sound like a metal on metal jarring but it does sound like something is moving that should not be.
I had a friend shift for me as I looked/listened underneath the car and I noticed something moving back and forth (as if there were loose hardware) somewhere along the exhaust system. It moves way more than I would like it to, and I don't see why it should move AT ALL. I don't know if the tranny, being close to that particular area, is the culprit or what.
I have no reason to suspect anything else is wrong considering the problem only arises during the shifting I mentioned above.
Please, at your earliest convenience, help me out if possible!
I am completely stressed out over this as I know transmission problems are major.
Thanks,
sleepyd
Old Aug 24, 2011 | 11:27 PM
master tech's Avatar
master tech
Site Moderator & Tech
Do you have the two or four door stratus?
Old Aug 25, 2011 | 02:13 PM
_sleepyd's Avatar
_sleepyd
I have the two door (R/T sport, 3.0L 6 Cyl).
Old Aug 26, 2011 | 12:40 AM
master tech
You could have a broken motor mount. But the reverse to drive doesn't make sense, because when you from park to drive its okay, but you still need to go thru reverse to drive.
