2003 stratus R/T
Old Sep 25, 2011 | 11:18 AM
D. Jackson's Avatar
D. Jackson
Default 2003 stratus R/T
My car sat with in idle for over an hour with AC on. When I went to drive the engine shut off when I hit brake. The gas pedal must be pressed to start. If you take foot off gas or press break the car shuts off. I checked vacuum lines for leaks and found none. What could the problem be. Thanks is advance.
Old Sep 26, 2011 | 11:23 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Have you tried to see how the engine runs with the A/C off? To me it sounds like the idle is too low.
