Low oil pressure shutoff?
Old Sep 28, 2011 | 07:31 PM
bvolks2's Avatar
bvolks2
Default Low oil pressure shutoff?
I have a chance to pick up a 1998 Breeze from a friend of mine cheap because he hit a pothole and busted the oil pan. The engine shut off and he had it towed home. We put some oil in it and it fired right up but as soon as the oil leaked down and the oil light came on it shut off immediately. We patched the pan up and had it running for about a half an hour with no problems so I'm wondering if they (2.4L) have a low oil pressure shutoff and the motor might have escaped any damage. There were no rattles or smoke when we had it running.
Also, the motor has an aluminum pan on it but everywhere I've looked says it should have a steel pan. Did any of these come with the aluminum pan or could this be a 2.0L block with a 2.4L head?
Old Sep 28, 2011 | 10:49 PM
master tech's Avatar
master tech
Site Moderator & Tech
There maybe a problem with the pressure releave valve or an oil pump.
Old Sep 28, 2011 | 11:21 PM
bvolks2's Avatar
bvolks2
If it originally had an aluminum oil pan will a steel one work? Clearance issues or anything? Every replacement one I've been able to find have been steel instead of aluminum.
Old Oct 1, 2011 | 12:33 AM
master tech
I would stay with what came off the motor.
Old Oct 1, 2011 | 12:59 PM
bvolks2's Avatar
bvolks2
That's the plan but I haven't been able to find one so far.
